93 toyota truck please help!
Old 10-05-2010, 07:35 PM
fusion1620's Avatar
My friend bought a 93 Toyota truck 4x4 3.0 v6. It was running when he first got it, now it just does not want to start? Engine is cranking over fine.. I have hit it with a timing light and the #1 cylinder is firing at TDC. Taken the timing cover off and the belt looks good and the marks are all lined up. The distributor is spinning. Sprayed starting fluid into the Intake and we can not even get a pop out of this thing. Compression was checked and is around 140 for each cylinder.. Any ideas? Help.
Old 10-05-2010, 07:39 PM
2DoorRunner's Avatar
Im not your engine guy, but are you even getting spark?
Old 10-05-2010, 07:42 PM
fusion1620's Avatar
When I take the plug out and set it on the intake manifold it is sparking. Yes.. Maybe when I screw it back into the block it stops working? Starter is shorting out the engine ground? Three Mechanics have looked at it and can not figure this one out so far.. Including myself..
Old 10-05-2010, 07:47 PM
Well thats all i got
Just wanted to help clearify what the problem was so you will get an answer sooner. And i read your first post wrong so i thought you wernt getting spark
Old 10-05-2010, 07:54 PM
fusion1620's Avatar
We have no idea what is wrong.. All three of us have good skills, so combined we should have figured this one out. Air,fuel,Compression, and spark. What are the best tests for a no start on these motors?
I feel like a Noob.
Old 10-05-2010, 10:08 PM
93yotaSR5's Avatar
did anything get wet? (mud puddles)?
Old 10-05-2010, 10:30 PM
fusion1620's Avatar
No mud puddles that I know of..
Three things happened just before it decided to never start again...
It was showing a knock sensor code and the wire to the knock sensor fell apart upon inspection.
The sensor and the pigtail have now been replaced..
It had a very bad rattle in the catalytic converter, so the one piece exhaust was cut, the cat was hollowed out, and the exhaust was clamped back together.
The last thing was a new battery was installed. This battery had the posts on the wrong sides so the battery so the wires got pulled on so that they would reach. Which they do, just barely..
Now it doesn't even try to fire..
Old 10-05-2010, 10:35 PM
94toy4x4fever's Avatar
Check all fuses in the engine bay and inside the rig.
Old 10-05-2010, 10:44 PM
fusion1620's Avatar
Thumbs up
All fuses are good.
Weird thing is that it has fuel, spark, and compression. What could be wrong? Maybe I'm not doing the test right..
Old 10-06-2010, 12:21 AM
kcorpetti's Avatar
When pulling the battery cables, make sure you didnt disconnect the car's ground. There should be a negative wire coming from the terminal and screwed right into the chassis.
Old 10-06-2010, 12:40 AM
kcorpetti's Avatar
Just realized, if you're getting a spark, then ground is not your problem. My bad! XDXDXD
Have you checked for Check Engine Codes?
Old 10-06-2010, 12:47 AM
fusion1620's Avatar
It is hooked up....
Starter will not engage when the smaller wire to the frame is unhooked. Even when the two big cable are. I assume this is normal..
The #1 cylinder is firing right at TDC with the timing light.
Compression is around 135 according to one mechanic, but I will have to check it for myself.
Sprayed starting fluid into the intake...
Engine turns over...
Nothing. No spark sounds like.
Take the plug out , set it on the manifold, crank it over, and it works...
Timing belt marks look good..
Fuel, air , compression, spark..
Fuel, air, compression, spark...
Don't understand..
At least I'm not alone.
Two other guys better than me can't figure it out either.......
Old 10-06-2010, 04:38 AM
norcal93's Avatar
Isn't 135 kinda low on compression? I thought the manual specified 150 as minimum compression. Still should give you something though.
Old 10-06-2010, 04:42 AM
TNRabbit's Avatar
135 is very low compression for the 3vze.
You replaced the knock sensor & wire, so you've had the intake off. You DO have the VAFM reconnected, RIGHT?!?
Old 10-06-2010, 04:45 AM
TNRabbit's Avatar
*duplicate post*
Old 10-06-2010, 09:15 AM
fusion1620's Avatar
You mean the air sensor on the intake right? Yes its hooked up. When I press the flapper in the fuel pump comes on.....
Old 10-06-2010, 12:25 PM
Foglifter's Avatar
Hmmm.. What kind of spark? Faint or good solid spark? Might have the coil chkd.
Old 10-07-2010, 05:03 PM
fusion1620's Avatar
Update!! What do you think??
Today one of the guys pulled the intake off the top of the motor so that they could get to all of the fuel injector wires and check for a pulse.. Turned the key over and she started right up!! Turned it off. Tried again.. Started right up again!! They put the intake back on and now it just turns over and over with no signs of life again.. I'll be looking into it tomorrow, so any ideas are helpful...
Old 10-07-2010, 05:32 PM
wmayota's Avatar
Try this...
Copy and paste this URL:
http://personal.utulsa.edu/~nathan-b...sm/engine.html
Unfold a paper clip and pull the cover off the Diagnosis box under the hood next to the fuse box. Stick one end in the E1 and Te1 terminals.(There is a a diagram under the cap that shows you what terminals are what)
Make sure that the engine is at operating temperature and turn the ignition to on. The check engine light will flash the # of a code (i.e. it will flash five time for a five, a brief pause, then once for a one, hense code 51.) On that URL I pasted (I forget which heading, but it is under one of them) is a list of coded that will tell you exactly what the problem is (assuming it is an electrical problem). Everything you could possibly need to know is on that website if you spend the time to look around. (I think I learned this in a thread from thook, but I can't remember)
The only other thing I can offer is that I had a similar sounding problem and it turned out to be the EFI relay switch behind the glove box and a few loose connections in the wiring harness. Now my truck runs fine. Good luck fixing it.
Just adding this for any others going through a similar problem, but if the light flashes repeatedly faster than hummingbird on coke, then you have no problems.
Last edited by wmayota; 10-07-2010 at 06:03 PM. Reason: Forgot to add some stuff...doh.
Old 10-07-2010, 05:45 PM
fusion1620's Avatar
After trying to start the truck. No trouble codes are displayed. Bummer..
Something with the EFI I think.. Not getting fuel with the intake hooked up? Not enough air? Guess I'll find out tomorrow...
Quick Reply: 93 toyota truck please help!
