93 runner build
93 runner build
Hey, so i just bought a '93 3vze auto 4x4
looking for some advise on a good setup for a DD and Trail rig. Looking to do some medium to heavy off road. It already has a set of American Racing rims and a set of BF allterrains of it now. Everything runs nice. It does have a few hiccups though.
Beyond 45mph it has a slight wheel rub sounding noise comming from underneath the driver side.
She has a slight low idle around 500rpm at temp.( will be adjusting the throttle screw today at some point.see if that does the trick.)
And from what i feel on up hills the tranny seems to slip at highway speeds. not in low gear. under 20mph
minor body rust nothing bad..
I already have some things in mind a full brake job (getting done this week) as well as a full OME suspension with a set of 33" allterrain T/A KO2.
Before i get into the lift is there anything I should check for ware / get replaced before going with the lift and larger tires.
thanks in advance for the info
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
