93 PU hesitates after warm up
Old 04-15-2011, 10:24 AM
1993jumper's Avatar
I am dealing with this prob. going on for 3 months! Glad I found you guys. Ive got a 1993 toy 2wd. 22Re put a fresh engine in went to an electric fan (just for a/c IN PHOENIX) anyway after about 300 miles that darn fan quit and it got a little hot since then it stumbles unless you have the pedel to the metal.
Had to advance the timing quite a bit just to get it to move! when timed properly it coughs out of the intake. Changed the head gasget just as a precaution and no change. burped it to many times to count adjust the tps no change. what am I missing????? Thanks for your suppoort.
Old 04-15-2011, 04:18 PM
Adk_Yota's Avatar
bad ECT sensor maybe
Old 04-15-2011, 04:26 PM
James Woods's Avatar
When you say fresh engine, what do you mean? Was it a rebuilt engine? Any machine work done? When you replaced the head gasket did you check for warped surfaces?
Old 04-17-2011, 10:33 AM
1993jumper's Avatar
had the head checked all is good there. it didnt get THAT hot boiled over Sitting at a drive though when it happened shut down right away. the engine was rebuilt at a well known shop.
Old 04-18-2011, 07:24 AM
1993jumper's Avatar
checked the ect checks ok rechecked the tps. Im missing somthing! it gotta be somthing simple Im missing
Old 04-19-2011, 12:41 AM
navman93's Avatar
Rebuilt...You pulled a 22re and had the same 22re rebuilt? Reason I ask is this....If it was a rebuilt 22r the timing is set differently than a 22re....Not trying to insult your yota intelligence, but you said "something simple."
Old 04-19-2011, 05:54 AM
1993jumper's Avatar
I bought a fresh rebuild 22re to replace the 22re I had. The new engine ran GREAT untill it got warm. now like crap. I think after some investigation I think Im gonna have to bite the bullet and take the head back off. and go to a Toyota gasket. Dont want to!!
Davebarbier
11-03-2015 03:28 PM
shredder4286
10-01-2015 01:09 PM
gentry
09-28-2015 06:16 AM
sanctfy
09-13-2015 06:33 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: 93 PU hesitates after warm up
