93 pickup 3.0 v6 overheats at idle?
Old 02-21-2010, 11:08 AM
BLAKE2182's Avatar
I have a 1993 toyota pick up with a 3.0 v6. I bought the truck and the engine slung a rod. I got a junk yard engine and had it rebuilt. Since I put the rebuilt engine in it keeps overheating at idle. I have made sure that i have no air pockets, replaced the thermostat and replaced the fan clutch. Any ideas on what i should check next.
Old 02-21-2010, 11:57 AM
BLAKE2182's Avatar
Is it possible to but the head gasket on the wrong side with the distributor.
Old 02-21-2010, 12:23 PM
buckz6319's Avatar
did you put your fan shroud back on?........how's the condition of the radiator and water pump?
Old 02-21-2010, 01:30 PM
BLAKE2182's Avatar
I put a new fan shroud on the water pump and radiator look good. I just pulled the thermostat out and drilled 2 holes in it. I let it run for 20 min and it did not overheat. I am going to go drive it when the kids get up from there nao I will let you know if it worked.
Old 02-21-2010, 01:55 PM
buckz6319's Avatar
sounds good keep us posted
Old 02-21-2010, 02:01 PM
BLAKE2182's Avatar
Looks like that fixed it. I took it on a short test drive and have let it sit at idle for another 20 min. The temp has not moved.
Old 02-21-2010, 02:09 PM
buckz6319's Avatar
good to here that some problems get resolved...good luck
Ditch Doc
10-27-2015 03:20 PM
kcaudill
10-10-2015 02:39 PM
shredder4286
10-01-2015 01:09 PM
taraf
09-25-2015 02:57 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: 93 pickup 3.0 v6 overheats at idle?
