| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
93 'peekup truck front gear change knowledge needed
__________________
Take the oil cap off and throw it away, you dont need that. May as well drain the oil, dont really need that either. Just extra weight, and without that extra weight, you'll gain like, 400 horsepower! I plagiarized this from DeathCougar |
#2 (permalink) |
Ummm ... this is one of those "if you have to ask, you probably shouldn't be doing it" kinda questions.
Have you setup gears before? Do you know if the bearings and such were replaced when the 5.71's were installed?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) | |
Staff
Wait a second you have 5.71's in your front diff and 4.10's in the rear and you've driven it this way?? Your best bet is to just replace the whole third member provided you still have an intact transfer case.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
#4 (permalink) |
The front driveshaft has not been in the truck since the gears were changed in the rear. Yes, I've set up differentials before but I cannot find a differential baring, seal and shim kit like I have for the others I've set up. All I can find are an inner pinion bearing, and a differential bearing for a qty of two. Federal Mogul does not offer a differential kit for this truck so I am on here asking where to get a complete bearing and seal kit. Since I drive this truck every day (big ass 2wd right now) I don't have the luxury of taking it apart and letting it sit while I gather the parts up.
Thanks, Chip.
__________________
#5 (permalink) |
Order a master install kit from Performance Offroad Center or 4WheelParts for the 7.5" Toyota IFS. It will have all the parts you need.
Actually, yes, you can take it apart while you gather parts up. The '93 has a full floating front end, so you can remove the CV's and the entire diff and drive the truck if you like. It sounds like you may not be all that familiar with Toyota diffs. Check out www.gearinstalls.com for info on them. Also, here is a link to the Factory Service Manual for your rig: http://www.personal.utulsa.edu/~nathan-buchanan/93fsm/
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action Last edited by tc; 01-05-2009 at 07:24 AM. |
#6 (permalink) | |
Quote:
Once again, Thanks for the help.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gear oil change | Al's Chop Shop | Pre 84 Trucks | 6 | 05-21-2008 01:38 PM |
| Front crank seal change in truck? | Beaniam | 86-95 Trucks & 4Runners | 20 | 03-03-2008 04:01 PM |
| gear oil change | 91TPU | 86-95 Trucks & 4Runners | 5 | 01-06-2007 02:05 PM |
| gear change | sefus | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 02-21-2005 10:18 AM |
| Coolant change, belt change help needed on 94 Toy Truck 4 cyl 2 wd | BravestDog | Maintenance & Repair Archives | 2 | 05-16-2003 11:11 AM |
