93 O2 sensor woes
Old 01-18-2009, 02:49 PM
thaddeusss's Avatar
93 O2 sensor woes
I recenty bought a new (for me) 93 4x4. 209k but the previous owner rebuilt the motor <5000k ago. the check engine lamp was burned out when I got it, I put a new one in and found a code 21 and 25. I checked underneath, found the wiring for the o2 sensor a little funky, so I spliced in a new section from a wrecker. also replaced the sensor with a new bosch unit. it's the 4-wire warmed version. I'm positive I wired everything correctly. now the code 25 is gone but the 21 is persistent. I measured the voltage from E1 to Vf1 and didn't get anything, no matter what I did. the FSM troubleshooting flowchart says to replace the ECM under that condition. I've never encountered a bad ECM before, so I'm wary of that. anyone have any ideas where to look next? is there a way to test the ECM, other than trying a different one? thanks...
Old 01-18-2009, 03:02 PM
Flash319's Avatar
What is 21? Whats the description?
Old 01-18-2009, 06:36 PM
thaddeusss's Avatar
code 21 is : open or short in : main heater circuit of oxygen sensor or main circuit of oxygen sensor, or failure of heater circuit or oxygen sensor. or ECM.
Old 01-18-2009, 06:46 PM
abecedarian's Avatar
so check for voltage on the O2 heater wires. If you've got voltage there, and a new O2 sensor, then maybe it is the ECU.
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
potatopants
09-15-2015 06:26 AM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: 93 O2 sensor woes
