93 4runner rear window removal problem
hey....soing... my rear window doesnt work (seems like a common problem)...anyways here is what is happening
The motor works...it makes noise at least when i pushed the button for up an down
I removed all the paneling to expose the motor assembly. I think that the arms have seized(rusted in place) in the up position. Now the other issue is that the window is up....so I am stuck on how to remove the assembly and/or get the window down.
Also wondering that if the motor is trying to move seized gears if it would develope a problem with wrecking its "output".
Thanks for any advice.
voiddweller
19
05-02-2016 09:10 PM
1993, 4runner, 93, disassembly, forerunner, malfunction, problem, problems, rear, removal, remove, runner, stuck, tailgate, window
