93 4runner, cranks no start
Old 11-03-2009, 01:46 PM
staticx's Avatar
thought id post in here since no answer in newbie section. So far its getting spark, the fuses and COR check out. Just disconnected the fuel filter and cranked it over to see if it pumped fuel through the lines and nothing spit out. That a sure sign its the pump? oh ya forgot to add my friend said its been sputtering a few days before.
Old 11-03-2009, 03:21 PM
rustyf99's Avatar
Search fuel pump or fuel pump relay on here - there's a trick to bypassing the relay to diagnose pump problems by jumpering two nodes inside the diagnostic connections. Don't recall the exact procedure or terminals, I remember just reading it here or on 4x4wire.com - also check this link: http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old 11-03-2009, 03:37 PM
xfactor203's Avatar
I am putting a fuel pump in my '95 right now (well, when I get a chance to work on it again). See my thread here: https://www.yotatech.com/forums/f116...-start-194037/
Long story short, I decided it MUST be the fuel pump because twice I got it to start (or spit gas, in your case) by hammering on the fuel tank, so maybe try that? However, I keep asking for confirmation that this is a good diagnostic and no one answers. . .
Good luck, dropping the tank doesn't look as bad as some people let on, provided things aren't too rusty under there.
Old 11-04-2009, 04:19 PM
staticx's Avatar
well we got the tank dropped. somehow the plug that plugs into the fuel pump itself melted. How does that even happen. Anyways we need to find that assembly. any ideas
Old 11-04-2009, 05:08 PM
Kiroshu's Avatar
Sadly you didn't have to drop the tank....you just wasted a whole day.... there is an access panel under the right rear back seat... Plug is melted? You mean the connector outside the fuel pump? Well that may be part of your problem... check the pump to the battery hard wired see if it still works.... if so then your going to have to get that connector repaired or hard wire it....
Old 11-04-2009, 05:20 PM
bugs1961's Avatar
This site http://www.toyodiy.com/parts/p_U_198...EA_2211.5.html shows that you can get the whole bracket assembly from Toyota but it doesn't look like you can get just a connector. I checked for an '89 since that is what I have. From the home page you can put in your VIN and find the part numbers for anything on the truck.
Old 11-04-2009, 05:40 PM
staticx's Avatar
thx for the help guys we will look into it. Kiroshu we checked for that access panel we didnt have that. only access we had was to a fuel line fitting. Its a 1993
vasinvictor
01-20-2016 12:39 PM
Ichneumon
09-27-2015 04:21 PM
camdenbuck
07-07-2015 07:33 AM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: 93 4runner, cranks no start
