93 4runner Annoying squeal
Old 11-27-2014, 09:05 AM
Charecter1's Avatar
Hey guys, I'm having a problem with my rear left wheel squealing LIKE HELL between 0 and 20mph, I don't even need to be braking for it to squeal. I took the drum off and the pads look almost new and I didn't see anything wrong so I just adjusted the screw to bring the shoes in and the problem was gone until I pressed the brake pedal again so I don't know what's going on. Its a 1993 toyota 4runner 3.0 auto.
Old 11-27-2014, 11:13 AM
rworegon's Avatar
Return spring not set-up correctly? Brake cylinder frozen?
Old 11-27-2014, 05:17 PM
ksti's Avatar
^As stated above.
Also shoes my look good but might be glazed.
Start with the basic's sand shoes, check for hard spots ( burn spots) on drum surface.
Have you driven with e-brake on lately?
Pull the shoes off and re-grease backing plates.
Old 11-27-2014, 05:36 PM
Charecter1's Avatar
Originally Posted by ksti
^As stated above.
I haven't driven with the ebrake on, I was g going to clean and lube everything and see if that helps, the right shoe was rough at the bottom and it felt like sand paper.
Old 12-04-2014, 09:58 PM
Charecter1's Avatar
Okay so update on the truck, I replaced the hardware shoes and cylinder but now the brake light is on and fluid isn't going to that wheel so u have no brakes on that wheel. What do I do?
Old 12-05-2014, 02:51 AM
rworegon's Avatar
Did you bleed the brake system after doing the work?
Old 12-05-2014, 07:23 AM
Charecter1's Avatar
I tried but I can't get that wheel to bleed.
Old 12-05-2014, 07:29 AM
rworegon's Avatar
Does brake fluid come out of that cylinder when the valve is opened?
Did you properly adjust the shoes before putting the brake drum on?
Old 12-05-2014, 10:59 AM
Charecter1's Avatar
No, no fluid comes out, I adjusted the shoes until the drum Sat tug
Old 12-05-2014, 11:47 AM
rworegon's Avatar
You'll need to determine if fluid is getting to the cylinder. Remove the brake line from the cylinder and see if fluid is at that point.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 93 4runner Annoying squeal
