93 2wd Toyota not starting
i have a 93 2wd toyota pickup i bought that has been sitting for awhile like years i have rebuild the motor put alot of new parts on it and its still not starting i replace the ecm the open circuit relay it has a new fuel put it has spark it has power to the fuel pump i ran a hard wire to the pump and got it to start but it would only run for a few seconds and die and then i found out the open circuit was y i didnt have power to the pump but now im stuck idk where to go now its like im not getting fuel but the fuel pump is working
It would help to know what motor you have and more about what you've replaced/rebuilt. The community here is very helpful and can help you get to the bottom of the issue if you can provide them with the right info, first. Good luck.
sorry i forgot that its a 22re i have put a new head on it new bearings rv cam all new gaskets new starter, alternator, water pump, belt, new ignition, new fuel pump, ecu, open circuit relay, radiator, flywheel, clutch kit, new battery
http://personal.utulsa.edu/~nathan-b...fsm/index.html
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
Work your way thru the "Does not start" toubleshooting check lists.
i dont have the time to do that i have 3 kids and i need to get this truck going cuz we have on car right now and we both work i have been having people give me rides and walking please can some one steer me in the way to go to what they think is wrong
You're going to have to do some troubleshooting on your own, buddy. Unfortunately we can't turn wrenches for you over the internet...
I'm just a newb myself so I can't offer too much advice but I do what I can... Those are links to the factory service manual for your exact truck. It has step-by-step guides for everything imagineable. Just browse through and see if you can find something you haven't checked/tweaked/replaced yet. Also, double check the procedures on the things you've already checked/tweaked/replaced to make sure you did them correctly.
Best of luck.
Best of luck.
The fuel pump should prime itself for 2 seconds when the key is turned on. The air flow meter tell it to turn on/off after that so make sure its in good working order.
bigblue82
10
07-06-2015 08:27 AM
