93 22re conversion to 22ret
Old 03-26-2013, 05:10 PM
rsfire541's Avatar
Hey, I've got a 93 truck with a 22re I rebuilt. I saw someone selling all the parts of the turbo set up from an 86 22ret. I looked a bit with no prevail. Anyone know if it's a decently simply add-on?
I'm mainly concerned about swapping wiring harnesses and ecu's? His comes with at least the ecu, not sure about wiring harness. But idk if it would be a mess converting.
Old 03-26-2013, 07:09 PM
wyoming9's Avatar
Red face
If I remember the wire harness is not all that much different .
it seems to me a lot of work for little gain now if you were going 7MGTE that would be much harder.
Old 03-26-2013, 08:25 PM
Co_94_PU's Avatar
Different compression ratio, so the wiring is the easy part
Old 03-26-2013, 11:37 PM
wyoming9's Avatar
Red face
My bad I had thought they all ready knew about swapping the pistons and drilling the block for the piston oilers
Old 03-27-2013, 12:03 AM
Co_94_PU's Avatar
here is some reading material
"site:yotatech.com 22re 22ret conversion wiring"
https://www.yotatech.com/forums/f116...e-22re-243825/
https://www.yotatech.com/forums/f116...arness-180235/
And this one outta keep you busy for awhile
https://www.yotatech.com/forums/f120/22ret-swap-260681/
And the Wiring diagrams can be found here. Just in case your head is not already on fire.
http://www.22rte-trucks.com/simplema...php?topic=91.0
Old 03-30-2013, 01:05 PM
rsfire541's Avatar
Thanks for all the info and stuff to read up on guys!
Old 03-31-2013, 01:48 AM
wyoming9's Avatar
Talking
Really alot of work for little gain.
Just watch these exhaust manifolds have a tendency to crack so if your going to do this look at parts in person before reaching for the wallet.
Also be aware that all the intake piping is obsolete from Toyota so figure on sourcing your own.
r3dfish
54
05-16-2016 10:31 PM
coleypull15
11-03-2015 07:41 AM
Jcrawl94
10
10-24-2015 04:34 PM
priest16
15
08-06-2015 07:43 AM
Quick Reply: 93 22re conversion to 22ret
