93 22 re question
It sort of depends. If you have an automatic transmission, there's 2 bolts that secure the water pipes. If you have a manual transmission, there's only one bolt that secures the water pipe.
Either way, the water pipe goes over the EGR crossover plate (this is the rear cyl head plate) and the bolts hold both pieces on.
Here's an ATM pic, ripped off from Jerry
Notice that there are 2 bolts for the water pipes
TJWilly
07-31-2015 02:05 PM
