'92 Pickup pulling left when braking
So I've noticed that when I brake I get a noticable pull to the left, and it is very noticeable, almost scary, under heavy or panic braking.
So I'm assuming I have a caliper issue on the right front brake, most likely the caliper is not sliding properly when pressure is applied.
Just wondering if this is a known issue with Toyota calipers, because I see in the records from the PO, that he had replaced the left front caliper at one point, so I may have to replace the right front caliper now, if I can't get it sliding again.
Anybody know what a new caliper cost for a '92 Pickup 4WD, 3VZE, 5spd?
Thanks.
Thanks.
Aleeex_u
06-05-2016 06:52 PM
bigblue82
10
07-06-2015 08:27 AM
