92 pickup not running. why?
Old 01-31-2009, 11:30 PM
92yotapu's Avatar
Angry 92 pickup not running. why?
story: it ran fine until it was pressure washed in the engine compartment. then it ran horribly. stopped running, i then replaced ecu. got it home and started looking at it again but it kept running horribly. i found that the o2 sensor was unplugged so i replaced it and hooked it back up. now it wont run at all. any ideas where i should start? it was throwing the MAF sensor also as a code but it had been replaced recently. maybe the tps? it was throwing that code also. i need help PLEASE!
Old 02-01-2009, 12:34 AM
toyota4x4907's Avatar
What engine?
What were the exact codes? There are more than one code pertaining to the said sensors.
Old 02-01-2009, 09:06 AM
TomThumb's Avatar
check to see if your EFI fuse under the hood is burned up. There have been issues with the O2 sensor shorting out on the exhaust, blowing the EFI fuse then the truck will not run at all. If the fuse is blown check your O2 sensor wiring for cracks or melting. Hope this helps.
Old 02-01-2009, 09:48 AM
Staff
DeathCougar's Avatar
Since its quite clear that this is directly related to the pressure washing, i would look at everywhere you sprayed. Go over the entire engine, and make sure nothing is damaged, our out of place.
If it was throwing MAF as a code, you might have damaged it when spraying it. Doesn't matter if you just replaced it 10 seconds before spraying the truck, never assume a part is good just because you recently replaced it.
Old 02-01-2009, 10:58 AM
Jollyradar's Avatar
Make sure the MAF connection is secure and dry.
Old 02-01-2009, 12:42 PM
92yotapu's Avatar
well i got it running again. i didnt personally pressure wash it. so im just running around trying to find out what exactly is going on. now it just runs extremely rough and when i put the foot the floor it pops and does not wanna rev up. no power whatsoever. thanks for the help
Old 02-01-2009, 12:43 PM
92yotapu's Avatar
also it was the damn EFI fuse that kept it from running, but the new O2 sensor helped none.
Old 02-01-2009, 12:46 PM
92yotapu's Avatar
oh and its a 22re five speed. if that helps at all
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
luckypig44
07-19-2015 11:25 AM
Odin
07-15-2015 09:28 PM
rondogracing
07-14-2015 07:00 PM
Quick Reply: 92 pickup not running. why?
