92 Pickup 22RE Coolant Leak
Yesterday I discovered a small puddle of coolant under my truck and found that it was coming from the air chamber/intake manifold gasket. Do any of you know if there are coolant passages running through that area? I searched but couldn't find anything.
The leak is coming from the gasket between the air chamber and the intake manifold, where the red RTV is. I checked all of the coolant hoses around the throttle bottle and they're dry. The coolant seeps out of the top of the gasket. I tried torquing the bolts down a little tighter but it still leaks.
Can't be leaking coolant there, don't doubt it's collecting there but it can't leak out there it would have to be near full of fluid todo so and that is the air intake pipe, eg no coolant passages.
Here is a picture of the intake with the plenum removed, from Philberts headgasket thread
See the thermostat housing where the upper radiator hose connects. I'd try there first, but it could be blowing back from one of the temp sensors also.
Good luck sir heres hoping it's not a cracked intake!
Spicer
06-10-2020 08:39 PM
voiddweller
19
05-02-2016 09:10 PM
bigblue82
10
07-06-2015 08:27 AM
