92 4Runner Brake issues...help?
Ok, today I replaced both R & L front calipers (plus pads), reconnected the brakes lines and bled the brake system. But now there is no pressure to the either of the front calipers. When I depress the pedal the only thing that works are the rear brakes. More so, when bleeding the system the rear brakes are the only one's receiving fluid; meaing the fronter calipers are receiving zero brake fluid. I have bled the master cylinder at least 5 times before bleeding the rest of the brakes system (passenger rear, driver rear, passenger front, driver front, LSPV).
When I bleed the master cylinder I get fluid from both outlets, but the one on the end seems emit less fluid than the first outlet. While bleeding the brake system I inadvertantly depressed the pedal to the floor; so...
Did I mess up my master cylinder or is it bad?
Do I have a bad brake booster?
Any advice from ayone....?
Thanks, exerphys
Thanks, exerphys
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
Jnkml
07-06-2015 01:20 PM
