'91 Toyota unlocked hubs are turning
Old 12-31-2013, 01:25 PM
GSBoone's Avatar
Question '91 Toyota unlocked hubs are turning
1991 Toyota 4x4 with manual hubs, one axle spins forward, the other in reverse in 2WD, unlocked. Truck has 1 1/2" ball joint spacers and diff drop kit. What is wrong?
Old 12-31-2013, 05:03 PM
90YotaPU's Avatar
It sounds like you have it jacked up are turning them by hand and it's acting like a typical differential is designed to.
Old 12-31-2013, 06:55 PM
houston's Avatar
diff shouldn't turn if the hubs are unlocked, could be something busted inside the hub, might be a good idea to pull them apart and inspect the mechanism/gears
Old 12-31-2013, 07:50 PM
GSBoone's Avatar
Thanks, I would of sworn I thought it was not a hub problem, but after pulling out right side hub, noticed bad internals and that shaft could not disengage. No problem to repair/replace.
Himashi
10-01-2015 07:29 PM
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
bowhunter1640
18
07-05-2015 03:30 PM
Bamripzit
06-20-2015 04:53 AM
Quick Reply: '91 Toyota unlocked hubs are turning
