91 toyota engine over heating
Old 09-25-2011, 09:30 PM
trout's Avatar
so i went to get fire wood on the week end and as i was climbing up the hill witch was about 18 to 23 % steep and i put it in 4 wheel drive and my temp went right up into the red and had to stop and let it cool off.... i have never had that happen before and i have used the 4 wheel lots but not that steep of a hill so i was wondering if that is just the way it goes or if my thermostat is going or gone thanx for the help...
Old 09-25-2011, 09:44 PM
4x4climber's Avatar
Is your fan clutch working properly?
Old 09-26-2011, 12:26 AM
wyoming9's Avatar
Smile
Putting the vehicle in 4 wheel drive should not cause it to overheat!! Nor the degree of grade.
If this is a 22r series engine they sometimes have a condition where the temp gauge spikes !! Temperature overshoot I think it is called.
Did you check the coolant level lately ?? Belt is tight??
Have you had the coolant out lately perhaps you have a air pocket ??
Is the radiator blocked or just dieing from old age ??
How did it work after it cooled down??
Was the firewood brought home ??
Old 09-26-2011, 09:11 AM
BMcEL's Avatar
Do you have an OEM two-stage thermostat? Good info here:
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Team420
01-12-2021 04:57 PM
Cesarl74
04-23-2016 06:07 PM
WI Girl
06-25-2015 03:45 AM
Old Red 94
06-16-2015 08:32 PM
Corey
06-30-2002 04:54 PM
Quick Reply: 91 toyota engine over heating
