YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 12-22-2006, 09:42 AM   #1 (permalink)
Personal Sales Rating: (0)
Reaper's Avatar
91 Toyota 22re will not start
About a week ago, my truck was broken in to and they stole my deck . That?s when the problems started popping up. I lost all instrument lights including ac/heat panel lights. I went to the parts store and put in new fuses. I replaced all fuses with the correct ones now my truck will not start. I can here the starter it just will not fire up. One more thing the engine fuse in the fuse box under the dash as no power going to it.
Reaper is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 12-22-2006, 09:44 AM   #2 (permalink)
Elton's Avatar
elton hostler
Send a message via AIM to Elton Send a message via MSN to Elton
did you tape up all the wires where the deck used to be ? ...welcome to yotatech and merry x-mas
__________________
07 Tundra d-cab limited 5.7L 4x4 was my moms r.i.p 3/19/11
98 4runner SR5 3.4L 5spd 4x4 E-Locker sold 10-2-11
91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06
97 honda civic lx 4dr ls vtec
Elton is offline
Old 12-22-2006, 10:04 AM   #3 (permalink)
Threadstarter [OP]
Reaper's Avatar
Yeah I taped up all the wires, should the check engine light come on when you turn the key to the on position. Are there more than two fuse boxes on a 91 22re?
Reaper is offline
Old 12-22-2006, 10:09 AM   #4 (permalink)
Elton's Avatar
elton hostler
yes the light should come on when you start it but it go's away and theres a fuse box under the hood by the battery check the fuse that says efi
__________________
Elton is offline
Old 12-22-2006, 10:19 AM   #5 (permalink)
Threadstarter [OP]
Reaper's Avatar
The EFI fuse is good, is there a way check if the EFI Main Relay is bad?
Reaper is offline
Old 12-22-2006, 03:13 PM   #6 (permalink)
PabloA's Avatar
you need two people to check the EFI relay, have someone turn the key, (not on) and put your ear next to the efi relay you should hear a click sound when the key is turned. I had this same damn problem, thinking it was the efi relay or fusing. Ended up being the coil wiring. Check the wiring from the coil to the distributer, even check spark plug wiring. My problem was the plug that connects the two(coil and distributer).
PabloA is offline
Old 12-22-2006, 05:27 PM   #7 (permalink)
Threadstarter [OP]
Reaper's Avatar
It's not the coil wiring I get a good spark from the plugs.
Reaper is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
22r, 22re, 4cylinder, 91, click, efi, fuse, makes, noise, pickup, start, starter, test, toyota, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
'91 V6 PickUp - Start Problems Trinok 86-95 Trucks & 4Runners 24 04-05-2007 07:21 AM
91 22re 2wd toyota being parted out desert whomper The Classifieds GraveYard 8 09-25-2006 03:53 PM
91 runner wont start 2003mikem 95.5-2004 Tacomas & 96-2002 4Runners 0 10-27-2005 09:51 AM
91 pick up cranks but won't start Matt79 95.5-2004 Tacomas & 96-2002 4Runners 4 05-23-2004 06:25 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
