91 Pickup Power Steering Issue - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-11-2013, 07:42 PM   #1
beensoko's Avatar
Hi friends,
I have replaced my steering column and power steering pump. but im still having the same problem. The power steering whines on and off, and it only works when turning LEFT.
Any ideas?? Im completely lost.
Thanks!
beensoko is offline   Reply With Quote
Old 05-12-2013, 12:32 AM   #2
Robert m's Avatar
have you bled the box to get the air out?
Robert m is offline   Reply With Quote
Old 05-12-2013, 07:25 AM   #3
Staff
Terrys87's Avatar
Sounds like you need to bleed the system. You turn the wheel from full left to full right several times. I find it easier to raise the front end on a jack and stands to take the weight off of it. It takes several times to get the air out.
Terrys87 is offline   Reply With Quote
Old 05-12-2013, 03:24 PM   #4
Robert m's Avatar
there is also a nipple on the box to let air out too but it gets every where in a hurry if you dont put some kind of hose on it.
Void Dwellers 1995 4Runner 4WD SR5 voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 19 05-02-2016 10:10 PM
Steering problems help please Bamripzit 95.5-2004 Tacomas & 96-2002 4Runners 1 07-19-2015 02:17 PM
Steering problems help please. Bamripzit Offroad Tech 5 07-13-2015 08:21 PM
small block 350 yota 1badyota350 84-85 Trucks & 4Runners (Build-Up Section) 1 06-28-2015 07:50 AM
Reese's 86 hilux paxanders 86-95 Trucks & 4Runners (Build-Up Section) 3 06-21-2015 07:29 AM
Tags
power, problem, pump, steering, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
