91 Pickup CEL Issue
91 Pickup CEL Issue
I have a 91 pickup 2.4L and the CEL does not light up. I can't remember if it has ever worked. I just finished a head gasket repair and I was wondering if any codes were present but I can't tell since the CEL does not work. (I have never checked for codes but assume my year/model does provide them through the CEL) I have verified that there are wires going to the Instrument Cluster for it and I checked that there is a known good bulb installed for it.
I check all fuses and they are OK. Only wished I had measured to make sure the bulb was getting power on the high side. Question - where exactly does the power come from for the CEL light? I assume the ECU provides the ground but I have never located the ECU. It probably is behind a kick panel. I assume that the ground for the bulb comes directly from the ECU?
Any suggestions on where I can find power/ground locations?
Thanks
Thanks
I would start by checking your diagnostic connector. At least by '93, there is a W pin (between FP and E1). That's the GROUND side of the CEL. You can probably use a test light to B+ (I prefer an LED; just get a 12v led panel indicator as it will have the integral resistor -- remember that polarity counts).
Bummer there is no wire contact on pin W on my diagnostics connector. Makes me wonder if the CEL is not functional on the 91 pickup. Guess I maybe stuck with measuring voltage at cluster connector or getting into the computer. There is 12 vdc from pin Bp+ to ground on the diagnostics connector.
Turns out the gauge cluster I swapped a while back does not have the template for the CEL. What a bummer. Even if the light was on I could not tell because the fuel gauge backing blocks the light. Power and ground seem to be at the cluster connector so I may just have to jumper in a bulb to read the codes.
I don't remember what model year the cluster I installed came from. I am pretty sure it was an older year. The original cluster speedo broke and was noisy and that is why I replaced it. Was surprised to discover this cluster does not have CEL template.
Mucci
02-04-2016 10:28 AM
PureTacoma_Tundra
PureTacoma_Tundra
12-08-2015 09:20 AM
altydog
12-07-2015 11:28 PM
