91 pick up v6 revs fine after it bogs down and almost dies first
Old 10-19-2009, 01:41 PM
travismillward's Avatar
Hey guys, just ran into an odd problem with my 91 toyota pickup (3.0 v6, manual).
So what happens is when i step on the gas pedal, the motor bogs down like it is going to die, it doesnt die it just takes a second and then revs up just fine, and if i'm already revving it has no problem. This just started happening today. Any thoughts?
Thanks!
Old 10-20-2009, 06:32 PM
abecedarian's Avatar
may be a problem with the throttle position sensor, air flow meter or maybe a small leak in one of the intake duct boots.
Old 10-21-2009, 11:07 AM
k, i'm gonna check those out.
here's an odd thing, the check engine light does not turn on.
also, yesterday when i got off the free way, the similar symptoms happened only this time the motor stalled and would not start, i pushed it off road, tried cranking the motor for a minute. it wouldn't start, then all of the sudden it started and ran just fine with seemingly more power then before? havent had the problem since! so odd...
Old 03-29-2010, 12:39 PM
Nughuffer's Avatar
any updates on this? Having a similar issue with high idle and then stumble almost to stall.
Longbed 90
03-11-2019 12:38 PM
mluz013
09-29-2015 05:53 PM
utahman
08-23-2015 02:04 PM
norcal98
08-10-2015 06:20 AM
defrag4
07-31-2015 10:50 AM
Quick Reply: 91 pick up v6 revs fine after it bogs down and almost dies first
