91 4Runner XFer Case Problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-17-2008, 07:50 PM   #1 (permalink)
I am a fairly new owner of a 91 4runner with an automatic. Since the weather started to get a little colder here in S. Vermont, I have been experiencing a problem that occurs randomly if I don't warm up the car before starting off. The problem is that without touching the 4WD lever, the transfer case is in Low Range right from when I start off. I can tell that the main transmission is doing its thing as I did get it to shift through all 4 gears once to verify the main transmission was working. Of course being in low range, I topped out at 35-50 miles per hour.
The most effective and reliable way that I have found to get the transfer case back into high range (again without touching the 4WD Lever) is to back up a good distance during which, I can feel the Xfer case shift.
I am pretty new to 4runners so I am hoping that someone may be able to give some input on this problem
Thanks in advance!- Jeff
Techrat is offline
Old 12-17-2008, 07:57 PM   #2 (permalink)
tc
tc's Avatar
On the automatics, the tcase is basically another 2 speed automatic transmission siamesed on the back. It shares the same fluid, etc.
My guess is the transmission fluid has never been changed and is bad. I always change EVERY fluid when buying a used vehicle just to be sure.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Price check R151F and xfer case bktaco General Vehicle Related Topics (Non Year Related) 11 06-08-2007 11:24 PM
Help: Removing xfer case output nut! gapguy 95.5-2004 Tacomas & 96-2002 4Runners 20 08-07-2006 06:09 AM
How often do you change diff & xfer case fluid 4Runner4Christ 95.5-2004 Tacomas & 96-2002 4Runners 24 12-12-2005 04:46 PM
Quick question on '95 3.0 xfer case capacity kscurl01 Maintenance & Repair Archives 1 09-29-2005 08:22 PM
2009 InternetBrands, Inc.
