91 4runner vibration at 2000 rpm
Old 03-31-2010, 12:19 PM
jwesty's Avatar
every time i shift from 1st to 2nd and i get to 2000 rpm there is a small vibration that occurs for about two seconds until my rpm gets up a bit. It does it every time and i can't figure it out, any ideas?
Old 03-31-2010, 12:21 PM
Kiroshu's Avatar
Sure its rpm related does it do it a certain vehicle speeds? At idle reved to 2k rpm does the vibration occur? If not its drive line related. First thing i think of is U-joints. Get under truck and see if there is play in the rear drive shaft u-joints. There should be "none"
Old 03-31-2010, 01:38 PM
jwesty's Avatar
I should have been more clear, it does it at about 20mph which is usually at about 2000rpm. does not vibrate when sitting still at 2000rpm.
Old 03-31-2010, 02:13 PM
Kiroshu's Avatar
Check U-Joints a drive shaft. Lug nuts tight? Any noise involved?
Old 03-31-2010, 03:11 PM
jwesty's Avatar
no noise, just the vibration. could the clutch have anything to do with it?
Old 03-31-2010, 03:12 PM
jwesty's Avatar
also, it's very smooth all other times.
Old 03-31-2010, 03:15 PM
Kiroshu's Avatar
Does it vibrate as you let off the clutch... At highway speeds is there and jerking or feel its missing?
Old 03-31-2010, 03:17 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Make sure your yokes are bolted down tight...
Old 03-31-2010, 03:19 PM
Kiroshu's Avatar
Yea driveshaft bolts for tightness...
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 91 4runner vibration at 2000 rpm
