91 4runner sunroof won't close
Ever since buying my truck the sunroof has been finicky when opening and closing, it would often stop and id have to jiggle the switch to get it to close all the way. Last weekend it stopped working all together while open. I removed the screw and pulled it shut manually but I can’t get the glass panel to raise that last inch or so to properly seal the roof. Is there a way to do this manually? I’d just like a way to have it sealed until I have time to fix the actual problem, I’m ASSuming that the problem is some sort of sunroof switch or motor or fuse. Hopefully not too expensive. Anyone have any experience with this kind of thing?
crashburnoveride
07-10-2015 06:39 AM
