91 4Runner mysterious suspension creak
Old 10-11-2010, 03:09 PM
amox's Avatar
So after driving from Alaska to Utah on my roundabout way to New Hampshire, my 91 4runner (~150,000 miles on the 3vze) developed a suspension creak. Everytime I would go over any small (or big) bump there was a very audible creak. It sounds like it's coming from the right rear and sounds like a slighty loose bolt.
I checked every bolt I could get my hands on and nothing was loose. Jumping up and down on the truck at a variety of points didn't produce the sound. However if I put it in gear and pushed the truck forward from the rear wheels I would hear the creak.
It is louder/more frequent when the there isn't much in the back. I'm thinking because of the test with pushing the truck in gear that it might not actually be a suspension issue, but it's most prevalent going over bumps...
any idea? I'm obviously new to this forum, and pretty green about this car maintenance stuff.
Thanks
Old 10-17-2010, 09:39 AM
skypilot's Avatar
Might be a bad shock. Failed bushing in the trailing arms.
Old 10-17-2010, 01:28 PM
angrydogtattoo's Avatar
I'm thinking bushing
Old 10-17-2010, 01:54 PM
myyota's Avatar
Spray a little WD40 or PB Blaster on the rubber bushings one at a time, let it soak in a little and then go for a short drive and see it the noise stops. Do each bushing one at a time until the noise stops, once the noise stops thats the bushing that was making the noise.
Old 10-17-2010, 03:06 PM
XDEADGOATX's Avatar
i had the exact same noise in the same place.....it lasted about a month or two and eventually went away....never could figure it out...was very annoying...
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Yota.Jay
07-23-2015 08:08 PM
Cdn-wilderness
07-10-2015 07:43 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 91 4Runner mysterious suspension creak
