91 4runner heat problems
Old 12-14-2010, 09:58 AM
Quentin27's Avatar
i just recently bought a 91 4 runner 6cyl. when the heater is on it blows very little warm air. I flushed the lines and that didnt work. Im gonna change the thermostat next if that doesnt work does that mean it is the heater core or could it be something else?
Old 12-14-2010, 10:24 AM
sabreuk's Avatar
id try blasting your heater matrix out with a presssure washer to clear out any crap that might of accumlated in the matrix, blow through both pipes till the water is clear then refill your coolant and bleed it through also do the same with your rad incase that is blocked with some debris, if its still cold id go change thermostat.
bigjstang
08-25-2021 12:41 AM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 91 4runner heat problems
