91 4Runner 4X4 auto trans Suspension lift question
Hello, I am looking at buying this 91 4Runner SR5 4X4, it's a great deal with the low low miles (92k original miles) The only thing is the lift on it. I do not want to keep it on there...I attached a couple of pictures. I would like to bring it back down to stock if possible. Can anyone help or give advice as to how I go about doing this? How much will something like this cost, and would I be able to remove the lift kit myself? Not too sure if it is a body lift or a suspension lift (what is the difference?)...can you tell by the pictures?
Thanks to anyone that can help out, much appreciated.
Brown28, Virginia
Brown28, Virginia
Body lift will lift the body off the frame.
Suspension lift will essentially push the suspension down away from the frame, which will lift the truck.
Looks to me like a body lift, though your pictures are not really clear enough to tell. Your mechanical skills will dictate how well you can handle a lift removal.
I can't see any pictures. Pics or more lift info is necessary to make accurate recommendations.
That said, all kits are removable but only you can decide if your skills, tools and time are up for it. We can only guess which isn't very helpful typically.
Frank
Frank
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
