91 4runner 3vze crazy high idle cold and warm
Old 12-06-2015, 07:14 PM
AZSPEED's Avatar
This is making me crazy. The idle is 2k plus the idle screw is all the way in. No intake leaks that I can find, vac line was cracked fixed still same problem. Checked throttle body and TPS all ok. Only thing left to check is the iac valve. How do I check it the screw is all the way in so maybe that is the problem.
Old 12-07-2015, 08:51 AM
Janos01's Avatar
That most likely is the problem. The car when cold shouldn't even hit 2k RPMs and when idle and in gear, should only be 500-800 RPM.
Old 12-22-2015, 06:17 PM
AZSPEED's Avatar
I took the throttle body off and found the coolant passage for the iac valve was plugged up and so was the iac valve. I took jb weld and filled the air hole in front of the butterfly valve and put it all back together. With the idle screw turned out 2 turns I now have 850rpm idle no more surging or high idle..... cost 4 bucks for jb weld. After sitting for close to a year with various problems it is now on the road. Currently has total chaos kit on it so next project is linking the rear end.
newzingo
12-08-2015 07:34 PM
Land
12-02-2015 01:06 PM
Mudlover
11-17-2015 02:04 AM
Zpayne21
11-16-2015 02:35 PM
jhsantacruz63
11-12-2015 08:12 PM
Quick Reply: 91 4runner 3vze crazy high idle cold and warm
