| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
'91 4runner 22r to 22re swap engine running problems
#2 (permalink) |
So, uh, what is it?
You hydraulic locked the 91 and put an 85 engine in a 90? Is the 90 the same as the 91? |
#3 (permalink) |
Meant to say 91 4runner. I'm having some power issues now. I took the throttle body off last night and I have it all cleaned up now. I think I need to check the fuel pressure tonight and the plugs even though there new.
#4 (permalink) |
I recently cleanned out the throttle body and intake manifold. I just got back from the shop and it is stil running ty... When in idle motor sounds fine. When I rev the engine I can go about half throttle and everything seems ok but when i open the throttle all open it really bogs down. GRRRR... I dont know what is causing this. I adjusted the TPS sensor all the way counter clockwise and it did adjust the idle down a little more which is at about 1200 rpms now. I definately need some help here. Thanks guys for viewing! I just dont know where to begin...
#5 (permalink) |
Any trouble codes?
__________________
1989 4R 3VZ Manual 32X11.50 BFG AT Saggy Butt |
#6 (permalink) |
Bogging down when you open the throttle up and idle dropping when you rotate the TPS, sounds like you're leaning out. No backfires? Checked for vacuum leaks? What is your timing at (with the jumper installed in the diag port)? All the valves adjusted properly? Exhaust / converter plugged up?
#7 (permalink) |
Just tested fotr codes and got a '24' and '31.' 24 is a Intake Air Temp Senson Signal and 31 is Volume Air flow Meter Signal. Any advice on how to fix those? Im gonna do some research here on the forum and see if I cant figure anything out. Some help would be sweet though!!!
| Tags |
| 22, 22r, 22re, 4runner, 85, 89, 93, backfires, cylinder, engine, fine, idles, intake, power, swap |
