91 4 runner engine demoblizer alarm system
Old 10-01-2008, 09:17 AM
shei's Avatar
So I just bought this truck and the alarm went off this morning when I was leaving my house. I was wondering if anyone knows how to disable the stupid thing so that my truck will start so I can go to work.
I called the local toyota dealership to ask if they knew how to disable it and they argued with me that the alarm wasn't stock in the vehicle. they told me to tow the vehicle to them so that they could look at it.
thanks in advance.
Old 10-01-2008, 09:35 AM
894x4pickup's Avatar
Look at the connections to the battery...if theres anything extra take it off and see if it works...you might need a wrench or a pair of pliers or somethin...
Old 10-01-2008, 09:45 AM
4runnerguy's Avatar
just cut the wire and there you go.
or find the alarm box and unplug and u are done
Old 10-01-2008, 10:05 AM
shei's Avatar
ok...do you happen to know where the alarm box is?
Old 10-01-2008, 10:25 AM
904_runner's Avatar
follow it around, it depends on the truck and where it was mounted.
Old 10-01-2008, 10:26 AM
shei's Avatar
so I disconnected the battery. that didn't do anything except set the alarm off. I have no idea what I am looking at for wiring stuff to disconnect the stupid thing. I am running out of ideas...
Old 10-01-2008, 10:47 AM
904_runner's Avatar
okay, look around, there is probably a little red led light somewhere inside the cab that should blink when the alarm is armed. you can take apart the pannel and follow those wires it should take you to the source.
is there any rmotes with the keys? what kind of alarm, if you can get the brand, you can get the instructions and you might want to keep it. Along with the alarm, there should be a horn inside the engine bay that emmits the alarm sound, disconnect and there shouldn't be any sound after.
I don't really know much about the alarms just trying to help you from having it go off every time you start the thing
It sounds to me like you just need to get the alarm to quit going off?
Old 10-01-2008, 10:53 AM
space-junk's Avatar
a lot of times the remote computer is located behind the gauge cluster...
Old 10-02-2008, 04:36 PM
Stein214's Avatar
Same problem. Was working on emission problem,failed Nox,replaceing vacuum line and decided to clean battery terminals. When I went to start my runner the alarm went off and it would not start. I have read countless threads to no avail. I would rather reset it as opposed to tearing it out as it has been no problem till now. I know it is something simple.
1992 4runner V6 3.0 automatic w/little red light and small toggle switch. Any input would be great as it's my only transport
Old 10-02-2008, 05:05 PM
just a 22re's Avatar
under the dash there should be a little black box with lots of wires coming out of it there should be a strip of wires on it unplug that and then try to start the truck it should fire right up
Old 10-02-2008, 05:19 PM
bigt's Avatar
contact the guy you got the truck from and ask whats up?
Old 10-02-2008, 05:33 PM
schmooot's Avatar
you will be looking for a small black box tied way up under your dash...up high by the gauge cluster. There will be a mess of wires plugged into it and 3 fuses right there. Pull them all and your truck should start.
Old 10-03-2008, 07:27 AM
Stein214's Avatar
Turns out my battery gave up! In the time it took to clean the terminals and reconnect them, it died. Still read 12.73volts on my meter, but alas, she was done. Put new battery in this morning which triggered the alarm, but it reset itself as soon as the truck started!! Hope this helps someone.
Old 10-03-2008, 08:04 AM
qdude79's Avatar
Ahhh.... so the alarm WAS working! Low voltage alert got ya! That's cool that you have a new battery and (hopefully) a fully functional alarm! No wiring guesswork necessary after all!
alfonz33
9
11-16-2015 09:21 AM
noahstancik
07-10-2015 11:18 AM
rwh2toyota
13
06-27-2015 05:39 PM
Mohamed
06-20-2002 10:42 AM
Vato Loco
06-08-2002 01:28 AM
Quick Reply: 91 4 runner engine demoblizer alarm system
