91 3.0 Wont start after alt install.
Old 01-14-2011, 01:59 PM
ChaseSS4R's Avatar
So I replaced my alternator, and when I did I took out the dizzy to get some more room. Now that I have everything back together, the 4 runner wont start.. It just turns over.. Any idea?
Old 01-14-2011, 02:07 PM
justin_4runner's Avatar
u have it back in the wrong spot, set timing at bottom and check that the dist is about 10 to 11 o'clock area.
Old 01-14-2011, 02:33 PM
ChaseSS4R's Avatar
So this is how it ends up after i try to turn it over..
Old 01-14-2011, 03:12 PM
yeah that doesnt look right, is the crank on the mark at the bottom? if so it should almost be 180 deg. from where it is, more pointing to the 10 and 11 o clock area,
Old 01-14-2011, 03:54 PM
ChaseSS4R's Avatar
Which mark? How would i get it to TDC?
Old 01-14-2011, 05:57 PM
use a 19mm socket down on the crank bolt and turn motor over tell u have the timing marks lined up. use a flashlight and look down the drivers side up front of motor and u will see the marks,
Old 01-14-2011, 06:14 PM
ChaseSS4R's Avatar
Hmm I dont understand how it would get that much out of time by just pulling the dizzy off
Old 01-14-2011, 07:33 PM
dizzy... disturber right? or just the cap? i was thinking u pulled it all the way out,.
Old 01-14-2011, 07:34 PM
ChaseSS4R's Avatar
Ya the distributor.. I pulled it all of the way out.
Old 01-14-2011, 07:45 PM
ok when u pulled it did u mark it or just pull and put back, it can easily get off a tooth or so when u do it, that's why its best to put it at tdc when u pull and put it back in.
Old 01-15-2011, 03:24 PM
ChaseSS4R's Avatar
No i didnt mark it, I just pulled it out..
Old 01-15-2011, 03:27 PM
so do u have a manual? look up timing in it and it should let u know where to set the motor and install the dist. back in.
Old 01-16-2011, 01:42 PM
ChaseSS4R's Avatar
I dont have a manual
Old 01-16-2011, 01:43 PM
go to the 89 to 95 section and there is one in there u can download it
Old 01-31-2011, 01:27 PM
ChaseSS4R's Avatar
K so got the timing marks lined up and the rotor pointed to number 1. Still wont start, just cranks over..
Old 01-31-2011, 03:05 PM
ChaseSS4R's Avatar
Ive checked everything with a voltmeter too. everything reads 12.5+
Old 01-31-2011, 05:16 PM
peckinpah's Avatar
Alternator fuse blown? My 22RE has an 80 amp alternator fuse that blew when my alternator went out. I had to replace both.
Old 01-31-2011, 05:17 PM
ChaseSS4R's Avatar
All the fuses are good.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 91 3.0 Wont start after alt install.
