91 3.0 vacumes clogged
Old 03-21-2011, 03:51 PM
91gen2runner's Avatar
After inspecting my egr and vacumes I found the steel tubes over the engine were clogged from a bad egr. Got a new egr, so is it ok to bypass the steel tubes with rubber lines? Please let me know
Old 03-21-2011, 07:32 PM
projectX4runner's Avatar
Yeah, im interested in hearing the answer for this too.
Old 03-21-2011, 07:44 PM
justin_4runner's Avatar
one of my lines where clogged... i did bypass it with rubber hose and did just fine.
Old 03-21-2011, 08:10 PM
Was your truck acting up before you fixed the line?
Old 03-21-2011, 08:25 PM
yes i was having issues with it.. i ened up replacing 90% of my vacuum lines and thats when i found the issue, after that it gave me my power back and idled nice...
Old 03-21-2011, 08:51 PM
Definitely gotta check out the lines on my truck. What kinda issues were you having with it when the line was clogged?
Old 03-21-2011, 08:53 PM
Ive gone through e erything on my 3.slow, just got the new egr, will install and roiute new vacumes tommorow, justin you said 90 percent replaced, were they all bad or were you trouble shooting till you found the bad ones?
Old 03-21-2011, 08:56 PM
Mine has lost power, and is non responsive when accelorater is pressed, especialy at idle and right after lond idles that fluctuate
Old 03-21-2011, 09:41 PM
well it just had bad idle all over, no power when i would get on it, slow to respond, i replaced a lot of them just cause one end was bad or cracked so i replaced it, i did one at a time so i wouldnt lose where they went, i would go and take a pic but just pulled motor to replace my trans as i blew it this weekend.
Old 03-23-2011, 07:02 AM
Wrenchinjoe's Avatar
Have you tried using compressed air to blow out the steel line?
If your EGR spat so much gunk that it clogged the steel line, I wonder what the inside of the intake plenum looks like?
You might consider pulling the EGR tube that goes into the plenum to see... if it is caked with carbon and sludge, you should clean that too. Getting rid of that gunk really helped my 3vze run more smoothly, during acceleration and at idle.
MadMax48
03-03-2020 10:33 AM
sanctfy
09-13-2015 06:33 PM
FJtoyman
09-08-2015 04:47 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: 91 3.0 vacumes clogged
