'91 22RE starter removal
Old 06-04-2009, 06:06 PM
Levis Pennae's Avatar
Yet another problem with removal of stuff. This time I need to replace the starter. The only problem is that the starter located in a void between the intake and EFI manifold and the front differential. I would rather not remove either one, any advice? I am replacing it with a rebuilt from Toyota.
Old 06-04-2009, 06:12 PM
toyota4x4907's Avatar
the starter is pretty easy to replace. go through the passenger's side wheel well. Its RIGHT there. You should be able to access both bolts from there if you are a contortionist, but at least one. The other one you might have to go up from the bottom, but you do NOT need to remove any of that stuff.
Old 06-04-2009, 06:15 PM
22repower's Avatar
On my 94 22re all that I had to take out was a small cover on the wheel well, and it seemed like no big deal.
Old 06-04-2009, 06:17 PM
toy89yota's Avatar
lots of extensions
Old 06-04-2009, 06:18 PM
Ok, thanks guys. I guess I've just been stupid.
Old 06-04-2009, 06:19 PM
Just Learning's Avatar
thats what i did on my 92 took the wheel off and removed the small cover on the wheel well --cake
Old 06-06-2009, 06:27 PM
I took Just Learning's advice, I was just a pain in the a$$ to get a wrench in there and even worst to get the torque bar in there.
Doug4320
03-24-2018 10:11 PM
clok
08-01-2015 09:42 PM
Hiluxtrucha
07-22-2015 10:00 AM
ZONAYODA
07-13-2015 07:17 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: '91 22RE starter removal
