Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
91 22re 4x4 pick up
__________________
85 celica gt hatchback 22re 10:1 compression,arp rods,crank scraper,fully ported head,.440 lift cam,fully ported intake,2.25 cat back exhaust,22ret injectors, 22ret ecu,22ret fuel regualtor,holley fuel pump.TO COME:arp head studs,600cc injectors,turbo cam,stock ct20 manifold ported,ct20-t25 adapter,t25 turbo 6psi,tubed outlet,3"down pipe,watermethanol (coolingmist stage3),aem wideband,adjustable fuel pressure regulator,front mount intercooler, mega squirt,750cc injectors,6-14psi,hopes 250-300whp |
#2 (permalink) |
Personal
Sales Rating: (0)
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
has anyone had this issue ?
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
Are you sure that the injector o rings are not leaking. Is the brass washer still on your fuel line.
Those are both possible things to check. Have some one crank it over you you look to see we're fuel is coming from
__________________
Old Toyota's Never Die..... .......They just get Rebuilt...... 87 Toyota Pickup, Built 22r 5-speed, 4x4 |
#5 (permalink) |
Personal
Sales Rating: (0)
orings and injector grommets...fuel line has 2 copper gaskets...
dry it all up and have someone start it while you inspect for leaks. be careful...no smoking!!
__________________
1981 Trekker! 1987 4runner 22r 5spd 31x10.5's Engnbldr rv head 268 cam Lc header 1999 4Runner Limited w/locker. 2001 Tacoma Prerunner 3rz Auto. 31's. |
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
Not out side the intake in side the intake ya I know werid yes allbthe orings are sealed yes have all the brass washers
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Also about 1/8 throttle there's a spot where it spikes 18:1 afr or the wideband won't even read it it gets so lean but a hair past it or befor its at 14.8 befor and 13.4 after that spot
| Tags |
| 22re, copper, fuel, line, oring |
