90 v6 3.0 harmonic balancer bolt
Old 07-17-2013, 09:32 PM
toyodug's Avatar
Lightbulb 90 v6 3.0 harmonic balancer bolt
Hi first time here, recently my power steering was going on and off after replacing the belt as it appeared to be stretched. then it threw the other belt and had a vibration. after inspection it turns out that the harmonic balancer bolt has come loose and disappeared. it sheared the key off and was just sitting there as the belts held it on. I need to replace the bolt washer and key. not sure where to start my search for parts
once again first time here and nice to find this site as I try to do all my repairs on my yotas
thanks Doug
Old 07-18-2013, 03:15 AM
RBX
RBX's Avatar
try the local wrecker / junk-yard / auto-recycler.
Old 07-18-2013, 05:30 AM
oldblue's Avatar
try the dealer. can't be too expensive for a crank bolt and a key. sometimes you can match up a key at a parts store, but if the old one is cracked or missing thats kind of hard to do.
Old 07-18-2013, 09:51 AM
toyodug's Avatar
thanks for the input called the dealer and can order the bolt for less than 10 dollars
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
gmonnie123
07-26-2015 02:44 PM
Gone Fission
07-24-2015 12:49 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: 90 v6 3.0 harmonic balancer bolt
