'90 PU alternator
'90 PU alternator
The 1990 Yota PU I'm working on was missing the alternator. When it was remover they simply cut the wires..
On the back of the alternator I'm missing the 3 prong round plug. I need it with about 5" of wire. Where can I get one, or do one of you guys have one I could buy?
I do have the single heavy gage wire connected and have been driving this way. What is the function of the 3 prong plug that I'm missing?
Thanks
Thanks
Send Cadman a PM, he is taking his off for a 3.4 swap:
https://www.yotatech.com/50842617-post57.html
That was a good question, so I googled it and found this:
http://www.autoshop101.com/trainmodu...or/alt101.html
'IG' is the ignition input that turns on the alternator/regulator assembly.
'S' is used by the regulator to monitor charging voltage at the battery.
'L' is the wire the regulator uses to ground the charge warning lamp.
SCZIG
09-20-2015 09:00 AM
