90 pickup firewall issue..
Old 01-30-2009, 11:12 PM
LilPyke's Avatar
ok so on my truck when i push in the clutch it seems the whole clutch bracket moves in. i looked around and when i push the clutch in the bracket moves in too and under the hood the slave cylinder moves back. (towards the cab) i think it the firewall is weak or something cause the metal like bends in and idk what to do makes my truck nearly impossible to drive. i was thinkn bout putin a peice of metal behind the slave cylinder to make the spot stronger buy idk if thatll do anything. anybody else know what to do or no similar problems?
Old 01-30-2009, 11:28 PM
Elton's Avatar
sounds like your clutch bracket cracked theres a few threads some where about this
Old 01-30-2009, 11:31 PM
mudcrasher's Avatar
is the firewall rusting? where do you live? is rust an issue where you are? friend of mine had a chevy pu that when you pushed in the clutch the cab would lift off the frame. ate a few clutches in under a few thousand miles and he decided to swap the cab. might be easier to swap the cab if the firewall is .
kazuya2416
04-05-2024 02:17 AM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 90 pickup firewall issue..
