'90 4Runner 4wheel drive gasket needs part/info!
Old 11-12-2008, 09:00 AM
deadduckky's Avatar
Was four wheeling the other day and picked up a steel fence post in the drivers front 4wheel drive and it appears only ripped the gasket closest to the tire. Not sure what this is called but I need a new one so dirt doesn't get it there, also any ideas on what all I have to do to replace this??
Thanks!
Steve
Attached Thumbnails '90 4Runner 4wheel drive gasket needs part/info!-compressed.jpg
Old 11-12-2008, 09:07 AM
904_runner's Avatar
Pics would be good. It sounds to me like you ripped a cv boot.
YOu can get replacement boots.
Old 11-12-2008, 09:19 AM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
904 is right. CV boots aren't hard to replace, but they are a PITA, tho.
Old 11-12-2008, 09:22 AM
deadduckky's Avatar
Hope this picture work guys...
Old 11-12-2008, 09:23 AM
rdlsz24's Avatar
Outer CV boot is what you need. You can get a kit at AutoZone, etc or the dealer.
Rob
Old 11-12-2008, 02:54 PM
deadduckky's Avatar
Any best way at putting one of these on!?!!?
Old 11-13-2008, 06:58 AM
deadduckky's Avatar
Anyone have experience with the Quick- Boot which looks like just slides over. I know that this is not the best but do you think it is good enough for only the 1,000 miles a year that i drive???
Old 11-14-2008, 11:37 AM
rdlsz24's Avatar
Here's a thread on how to change an inner boot: https://www.yotatech.com/forums/f116...v-boot-156096/
Outer boot is not as hard to get at so it should be less of a job.
Rob
Old 11-14-2008, 06:15 PM
deadduckky's Avatar
thanks!!
Old 11-14-2008, 11:06 PM
space-junk's Avatar
stock outer boots, IIRC, are like 22 bucks a pair at the stealership... and those come with new clamps too... might need to regrease everything tho...
Old 11-16-2008, 05:33 PM
deadduckky's Avatar
Does anyone know how I can replace the outer boot without taking apart the inner and the 6 bolts holding it up??? I've got it to the point where the wheel and is off and the cv is hanging there!
JF9243176
10-08-2017 04:21 AM
voiddweller
19
05-02-2016 09:10 PM
JF9243176
06-24-2015 04:53 AM
Quick Reply: '90 4Runner 4wheel drive gasket needs part/info!
