90 4Runner
Old 03-15-2008, 06:17 PM
Nickbo's Avatar
90 4Runner
My 90 4Runner has a 3.0 auto with stock gears and 33's on it. I got two questions, should I lower my gears? Next my 4Runner has been sitting for a few months and I just started to drive it again but when I shift into 4X4, it will shift into it and then shift back out: the 4wd light will flicker on and off. Can anyone help me out?
Old 03-15-2008, 10:52 PM
Dare44's Avatar
i would say if its manual tranny gear to 4.88, if its auto 5.29. and i would check ur electrical that sounds like a bad or dirty connection to the transfer case causing it to do that, maybe not for sure.
Old 03-16-2008, 04:11 AM
91 4Runner's Avatar
I'm thinking more of a vacuum issue with the actuator. I had a similar issue, when it was covered with mud it worked fine, when clean it would shift in and out. turned out there was a small leak in the rubber line.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 90 4Runner
