89 yoda starter
89 yoda starter
replacing everything on this yoda i bought a couple months ago clutch transmission all that but im having an extremly hard time getting the starter out i got the bolts off i just cant seem to get it out lol if someone could give me some insight besides taking off the motor mount on a 89 yoda 3vz engine that owuld really help
Oh thank God. I fought and fought to get the damn battery cable hooked back up since there wasn't any room for my little arms in there. At one point I thought about cuttting in an access hole just to make it easier.
Easiest way i have found to remove the starter is to remove the 2 12mm holding on the clutch slave cylinder (this allows the setup to move) then remove the two 14mm starter bolts with a long extension. Long enough to be in front of the diff. Makes it 200x easier.
I removed the charcoal canister and took off my jacket and was just able squeeze my arm to reach the top bolt (actually, its a stud and nut) with a box wrench. I did scratch my arm to on the fuel line brackets. For the bottom bolt I used a 10" extension and turned it through the access panel.
You're probably going to need a breaker bar to break the nut and bolt that hold the starter to the bellhousing loose. I slipped a pipe over the socket wrench.
zombie_barbarossa
10-02-2015 10:54 PM
FS[NorAtl]: 86 Toyota Pickup 4x4, 5spd, 22R 1500 (RUNS)
ToyotaMD
09-07-2015 04:44 AM
