| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
89 truck exhaust/cat
#2 (permalink) |
Did you up the size of the piping?
Removing the cat could cause loss of low end power but will free up the high end power. Its a trade off. I would recomend putting in a freeflow cat to see if that helps.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#3 (permalink) |
yeah went to 2 1/2 inch pipe and it is pretty sluggish on the bottom end. It was running fine all day today and then just a few minutes ago i drove it and all through first gear i was hardly even moving and it took untill about 2500 rpms in second gear to finally feel the truck get up and go. I hear a rattling sound too, dunno whats up. Ill check it out in the morning and post up what i find out.
Im deffinately thinking about a aftermarket cat, it just has been a hassle since i ended up paying 60 bucks to replace the cat and dont want to spend more money putting a new one back on, but thats a whole different story...... |
#4 (permalink) |
what engine do you have?
22re or 3vze If you have the 22re then that noise might be your timing chain. In any sence a 2.5" straight pipe is way to open for these engines..
__________________
#5 (permalink) |
why would his exhaust effect the timing chain?
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#6 (permalink) |
yea its the 3vze, and if a straight pipe is too open then would it be better to add in an aftermarket cat or adjust the mixture (If that would even help? i know nothing about EFI....)??? But i race motocross and i know on my bike i have to rejet the carb when i get a new exhaust, so im assuming the same would hold true for a truck, but like i said, i know nothing about EFI.
So which do you reccomend is easier, if this is my problem, im still going to check it out today and see what i can find. Thanks |
#7 (permalink) |
EFI tends to adjust the mixture for you (within limits)
#8 (permalink) |
2 1/2" is on the larger side of exhaust pipes for the 3vze. Increasing your exhaust pipes just a 1/4" in diameter adds 23% more volume to your pipes if they are all the same length roughly. That's 23% more volume that your exhaust gases must remain hot in to move. As soon as they cool they start to slow the flow which hinders exhaust flow and works against your engine. But when you rev the piss out of it you are getting more exhaust pulses which starts to move the exhaust again.
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids| Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 323,600 KM's (202,250 miles) | Made in Japan - Vin starts with "J"| Fish on |
#9 (permalink) |
well thanks for the help so far, i took the truck out for a drive this morning, it seems to rune fine. The noise was coming from up front towards the fan, either a bearing or a belt, but i sprayed it down and it stopped for now, ill keep an eye on it.
as far as the exhaust goes, truck is sluggish on bottom end but i can deal with it, it runs better than before im just wondering if it was a mistake to up the size of the pipe. It seems to have destroyed my gas mileage though, which sucks because it wasnt that good to begin with. just one last question, will placing a cat back in instead of having a straight pipe help boost my mileage a little bit?? something like a flowmaster aftermarket cat or something |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
thanks, that makes sense, i trashed the cat but i might end up buying one soon. I just checked my codes and got code 21. When it cools down at night the truck runs pretty bad, so im thinking the o2 sensor is out, is there a way to check the sensor before spending the 60 bucks for a new one?
Ive checked my wires and they dont seem to be melted/damaged. The sensor is stock as far as i know and i have about 204k on the truck so im sure its prob worth getting a new sensor. i want to see how it runs after working out the o2 sensor first, and if i still have similar problems i may reduce my pipe size and/or add a cat. |
#12 (permalink) |
A new O2 sensor wouldn't hurt, but in most cases it should throw a code (is code21 an O2 sensor). I think there is some way to check the conductivity of the sensor but I'm sure someone with more experience will chime in.
Put a high flow cat on and get a new O2 sensor and you should be set. If it still sucks bottom end wise, consider going to smaller pipes, OR going with some headers as they may help with scavenging/movement of exhaust a bit.
__________________
#13 (permalink) |
thanks alot coed, you've been a big help. The truck is throwing a code, and yes 21 is an o2 sensor. Im not too concerned about the loss of low end power at the moment, i just really want to fix my mileage.
My gas mileage dropped from 17mpg to about 12mph. Is this from the muffler, larger pipe size, or removing the cat... or a lil of all i guess. |
#14 (permalink) |
o2 sensor can have that negative effect on gas milage
__________________
1994 Toyota 4x4 22re |
#15 (permalink) |
#16 (permalink) |
Also, flowmasters have one of the best sounds, but there are definately a lot of better flowing mufflers out there.
__________________
#17 (permalink) |
He ment when an o2 sensor goes bad it can effect gas milage pretty significly ( around 5mpg )
You can get one from www.sparkplugs.com for pretty cheap, I got my NTK for 38us or so. But I would slap on a cheap cat at the same time, magnaflow's are pretty cheap. Drew303: I ment the rattle might be his timing chain, but since he sprayed the front of the engine down and it stopped, I would assume its not.. Sorry if I wrote it confusingly. (is that a word?)
__________________
#18 (permalink) |
that rattle could also be the muffler tapping the frame when going over bumps or whatnot... if you dont do anything else for a while i'd at least butt weld in a peice of pipe thats the same diameter as the rest of the exhaust(instead of the bigger piece you put in place of the cat.), for the time being..
__________________
My MYSPACE - You know you want to request me. '03 chevy S10 ZR2 SAS, D44 F/R 4:30's 35" MTZ's on MT Classic II's... '91 Pickup SR5 3.0L, 5-Speed, 4in ProComp, SOLD. <-- You Will Be Missed! 06.14.09 6:45pm. '91 4Runner SR5 3.0L, Auto, SOLD. <-- You Will Be Missed! 05.07.08 6:00pm. |
#19 (permalink) |
well i drove the first time on the highway today with the exhaust, deffinately get better highway mileage, but my city milage dropped about 5mph. whatever im over it. Ill get a new o2 sensor and be good to go.
the thing runs great when warm, but ive noticed after sitting all night it runs terrible, so im worried how it will run in the winter haha. guess ill have to get a cat on there before hand. thanks for all the help |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| cat back exhaust | andrew241 | 86-95 Trucks & 4Runners | 26 | 11-13-2007 10:12 PM |
| exhaust and cat questions | fullmann | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 01-17-2007 10:36 PM |
| Cat is poopin the bed need new exhaust | focuz04 | 86-95 Trucks & 4Runners | 8 | 12-15-2006 06:52 AM |
| Borla Cat-Back Exhaust, how is it? | petros | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 07-28-2006 11:20 AM |
| cat back exhaust? | mnm3783 | 03+ 4Runner/GX470, & 05+ Tacomas | 2 | 03-20-2006 12:12 PM |
