89 toyota 4x4 grabbing ruts bad
My 89 toyota is a pain to drive. Everytime i hit a rut even on the highway, i will jerk to one side. Could this be fixed somehow? Alignment?
most likely alignment and new steering staballizer maybe new tie rod ends also have you looked into the toyota relay rod recall my truck did the same as your and I took it in for the recall and now its better but still needs new staballizer and alignment
If your alignment is out too bad, your truck will tend to dart around when you hit a bump.
Check out your front end for wear:
Wheel bearings
tie rods
idler arm
steering stabilizer
Wheel bearings
tie rods
idler arm
steering stabilizer
Crazy_Guy97
12
06-24-2015 04:02 PM
Corey
24
07-15-2002 07:53 PM
