89 Toyota 3vze Throttle Body issues
Old 03-12-2012, 05:25 PM
azcheese's Avatar
My truck idles high and I have the Throttle position sensor Check Engine light. Ran the test on the TPS at the unit, form the ECU and adjusted it to no avail. My throttle body is pretty nasty though there is a valve inside that is rusted up and sticking. not sure what it is, Idle air bypass maybe? I have decided to replace it but they are $500 bucks online. so I am going the used rout. My real problem is i don't really understand the throttle body itself, is there anything i need to be aware of? what years are compatible? does it matter if it is a manual?
Your help would be much appreciated, Thanks!
Old 03-12-2012, 05:32 PM
toastyjosh's Avatar
First off pull that thing out, order a new gasket, clean the living ˟˟˟˟ out of it, remove the TPS before you get to crazy. (you could get it ported a few mm while its out if you want), reinstall with new gasket, adjust the TPS.
Old 03-12-2012, 05:36 PM
azcheese's Avatar
I have for the most part, in some parts its beyond cleanable. Its corroded to hell, the guy i bout it from felt that strait hose water was a suitable coolant (already flushed the system)
Old 03-12-2012, 05:48 PM
toastyjosh's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
tps info.
A another TB may be in order.
Old 03-12-2012, 05:51 PM
toastyjosh's Avatar
good source for used parts
http://yodajims.com/Yoda_Jims/Yard.html
Old 03-12-2012, 06:18 PM
ksti's Avatar
Wow, wondering what else is corroded. Was there any coolant in there at all?
Old 03-12-2012, 08:46 PM
azcheese's Avatar
There was a little bit, I really don't want to know what else was corroded... Im sure ill find out...
thanks for the links!
Old 03-12-2012, 10:22 PM
btu44's Avatar
I just installed an aftermarket cruise control on my 89 3vze manual truck.
I used a throttle body off a 92 4Runner that I got for $40.
PM me if your interested in my original one for the same price.
JF9243176
10-08-2017 04:21 AM
94 Newbie
07-06-2015 04:23 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
JF9243176
06-24-2015 04:53 AM
Sandman
06-18-2015 11:06 AM
Quick Reply: 89 Toyota 3vze Throttle Body issues
