89 speedo cable
Old 01-29-2011, 07:20 PM
ford97's Avatar
89 speedo cable
Hey, just bought an 89 toyota 4x4 and it is making a squeeking/whining noise when i drive it, im pretty sure that it is the speedo cable. Where can i buy i new one? cant seem to find one.
Old 01-29-2011, 07:21 PM
Staff
DeathCougar's Avatar
Buy one from Toyota
Old 01-29-2011, 07:28 PM
ford97's Avatar
is there anywhere else i could buy one? toyota will most likely be expensive.
Old 01-29-2011, 07:31 PM
Staff
Do you want it to work, or is all you are concerned about is how much it costs?
You have been looking for how long, trying to find the part? And you say you "can't find it anywhere". Thats not true, you CAN find it at the dealer you just don't want to pay the price. Why mess around trying to source it elsewhere, the whole time your speedo howling, instead of just fixing it and being done with it?
Try 1sttoyotaparts.com or toyotapartsales.com and order it from them for a discount.
Old 01-29-2011, 08:33 PM
survivorman97's Avatar
http://www.jcwhitney.com/cables/toyo...2193j1s21.jcwx
I think that one of these may work for you if you just need the cable and a lot cheaper.If it doesn't work then its off to the dealership or the junkyard. You may try taking the speedometer out and take it apart and cleaning a lubing it. Maybe also try lubing the old cable with some of the lubricants listed in the link above. Its possible that thats your problem. good luck
Old 01-29-2011, 08:39 PM
YakBlack's Avatar
salvage yard
Old 01-29-2011, 08:46 PM
clocklaw's Avatar
My 95 does the same thing...so did my 85 2wd.....anyone have luck lubricating the cable?
Old 01-29-2011, 08:55 PM
Staff
Those cables won't work in our trucks.
Needs to be OEM or an aftermarket equivalent, which I am not sure they make.
Old 01-29-2011, 08:58 PM
Blue 89 Runner's Avatar
FWIW, I bought one at NAPA a while back for my Runner .
kawazx636
10-06-2021 03:03 PM
Truckwithoutaname
10-03-2015 03:41 PM
charlie_fong
09-27-2015 10:06 PM
rmill05
09-27-2015 01:43 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: 89 speedo cable
