89 Rear main seal replacement
Old 12-23-2005, 10:16 AM
bryanr's Avatar
I will be having my rear main seal replaced sometime in the upcoming month. I haven't called any shops yet, but roughly how many man hours or how much $ to replace is this typically? Is there anything else I should do while it's out? Would it be easier to put headers in while this is being done? Thanks.
Bryan
Old 12-23-2005, 10:58 AM
suprathepeg's Avatar
All that has to be done is the shop will have to pull the tranny to get at the seal. From what I've heard its not so bad to do yourself in a day with standard tools.
Old 12-23-2005, 11:03 AM
eric-the-red's Avatar
You might want to consider putting in a new clutch, if your's has some miles on it. It's a lot easier and cheaper while the tranny is out than doing it later.
Old 12-23-2005, 11:07 AM
Elton's Avatar
changeing the clutch is a 4 hour job easy i did mine last week with a freind
Old 12-23-2005, 11:37 AM
bryanr's Avatar
It's an Automatic transmission, so I'm not sure if there's anything I need to replace while it's down.
Old 12-23-2005, 11:48 AM
Radyota's Avatar
Front tranny (torque convertor) seal for future insurance? If you don't mind replacing some fluid, that is.
Old 12-23-2005, 11:52 AM
:pat: now that I read your sig I see that, Oh well forget about the clutch then
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
Alaskan91
09-21-2015 04:39 AM
cchinny
06-25-2015 08:11 PM
Quick Reply: 89 Rear main seal replacement
