'89 interior wiring diagram help
Old 01-26-2012, 07:42 PM
jjw2w's Avatar
Hi all am in need of some help getting my brothers ’89 4x4 v-6 std pickup back to driving status after setting in his pasture for the last 12 yrs.
What I need is an interior/under dash wiring diagram. From left to right side kick panels.
We got it running, have redone the clutch and brake hydraulics, and ran into a problem with the gauge fuse blowing.
Had a wire smoke a little on the back of the interior fuse box coming off the relay integration module on the 3rd fuse. Black with a brown stripe wire.
That wire splits into several same colored wires that run to several places across the dash then to a relay mounted on the right side behind/above the kick panel.
I’ve been unable or in the interior.(other than the one noted)
Without knowing what that wire is supposed to do and what all it goes too I can’t put it back together and have the gauges working.
All he has is a Haynes manual and of course it doesn’t have the interior wiring diagram.
Or maybe some info from someone that has had problem with relay integration module, or knows what the relay I'm talking about goes to, or that knows what black with a brown stripe wire I'm talking about.
I haven’t been able to locate one online so, I’m asking if anyone has the Toyota factory wiring manual that can post me a link or email me a copy it would be much appreciated.
Thanks
Jay
Old 01-26-2012, 07:46 PM
justin_4runner's Avatar
link for the fsm and in there is the electrical section...
http://www.ncttora.com/fsm/index.html
Old 01-27-2012, 06:12 AM
jjw2w's Avatar
Thanks for the link.
While I’m fairly proficient using the search function, I haven’t found the FSM wiring for a ’89 there…but I’m still looking
Jay
Old 01-27-2012, 06:34 AM
jjw2w's Avatar
Well after going back the FSM page loaded. The first time it took me somewhere else?
Any ways still nothing for what I’m looking for, but I’m still trying.
Thanks again the search continues.
Jay
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
okamikai
04-30-2018 10:19 PM
montanatruck
02-26-2017 07:07 AM
TDonkey
07-26-2015 10:14 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: '89 interior wiring diagram help
