89-95 2wd spindle lift
Old 05-09-2006, 01:36 AM
jpwesly031's Avatar
hey im thinkin about lifting my 93 2wd pickup with spindles until i can afford a 3k custom front suspesnion. i was thinkin fagtech? then sell them when i go custom? any suggestions are welcome
Old 05-09-2006, 04:17 AM
RustBucket's Avatar
Save up for a 4x4 first...?
Old 05-09-2006, 05:26 AM
subliminaltrips's Avatar
i have fabtech front spindles and i havent had any problems other than they are now discontinued and hard to find and the steering knuckle bolts are easy to bend, i upgraded to a harder bolt and havent had any problems. if you look at total chaos's 2wd ball joint system they actually use a lift spindle that looks almost identical to the fabtech spindle, they either used fabtech's or they have made their own, you might wanna call them. a lift spindle in the front is a good way to get the vehicle up higher for bigger tires and is better than a body lift being you gain ground clearance. id say if you can find spindles go for it, then combine it with another system like total chaos's or downey off road's
http://www.downeyoff-road.com/Suspen...ents/index.htm
http://www.chaosfab.com/toyaccess_taco.html
JustMike
04-21-2016 07:08 PM
09-04-2015 09:27 AM
Pedalpwr27
08-13-2015 06:37 AM
coffey50
07-28-2015 10:55 AM
colasurdo
07-16-2015 11:32 AM
Quick Reply: 89-95 2wd spindle lift
