89 4runner IFS ADD or not
Old 05-07-2010, 02:40 PM
c0ugar69's Avatar
I have a 89erunner that i purchased a couple of months ago and it has the live axle hubs for the ADD setup but there is no vacumm actuator on the axle. My thinking is that it was a auto hub and they put the ADD hubs on it. I know when in 2H I cannot turn the drive shaft freely. I think that the differential is always turning as well as the drive shaft. I think putting some manuel hubs on will fix the problem. just want to make sure I am on the right track here. thanks
Old 05-07-2010, 04:48 PM
jskijoe's Avatar
I didn't think the ADD came out in the 4runners until '90. Is yours a 1st gen body? If so, it may have the automatic hubs where you have to do the reverse and forward shuffle to unlock...
Old 05-07-2010, 06:01 PM
c0ugar69's Avatar
thats what i was thinking but it has the live axle hubs on it now, I am thinking that it had auto hubs stock and someone changed the hubs to the ADD type but now my diff and drive shaft are always turning.
Old 05-07-2010, 06:57 PM
SoCal4Running's Avatar
My 86 had ADD hubs when I got it and am pretty sure they were stock. They unlocked in reverse, no vacuum components.
Old 05-07-2010, 08:00 PM
c0ugar69's Avatar
I think the hubs that you had were called auto hubs, they did unlock in reverse.
Old 05-07-2010, 08:13 PM
c0ugar69's Avatar
there is my front axle, no vacuum switch or actuator.
Old 05-07-2010, 08:17 PM
c0ugar69's Avatar
here is my hubs. so all I need to do is put on some manuel hubs and i should be good to go right???
Old 05-07-2010, 08:19 PM
Kiroshu's Avatar
ADD(Automatic Disconnecting Differential) <As far as i know didn't exist on toyotas till 90 and a few 89 trucks. The old pre-90's yotas with the automatic locking hubs worked on a racheting effect and working with the t-case.
Old 05-07-2010, 08:20 PM
Kiroshu's Avatar
Yea if thats on an 89 4runner then thats wrong and not OEM.
Old 05-07-2010, 08:24 PM
BigBluePile's Avatar
what the hell?!
That looks like some yahoo put a drive flange on to replace, which probably broke like mine did, the auto hub. Take it apart and see whats in there and get the right parts to put on there...
Old 05-07-2010, 08:26 PM
My bad, yea with a Drive Flange like that your axle shaft and front differential are always going to turn as well as your front drive shaft.
Old 05-07-2010, 08:28 PM
oh yeah the whole kitten cabuttle is gonna be turnin and wearin the hell outta everything...Don't be drivin over 55 LOL!!!
Old 05-10-2010, 01:11 PM
c0ugar69's Avatar
thats what i was thinkin, I need to get some manuel hubs on there as soon as I can, I should hae bought the one i saw at the wrecker, i could have put one on and made it work like the add for now. ohh well more money to spend.
Old 05-13-2010, 07:54 PM
c0ugar69's Avatar
Well i just removed my ADD hub locks and I am driving it without anything on there till I get my manuel locks..I have some being shipped now so it will only be a few days. I just put the center cap back on to keep stuff out of the bearings. What a difference it made unlocking the axles, it drives much better, exspecially on the freeway. I will get some pics when i get my manuel hubs. thanks for any help.
Old 05-13-2010, 08:01 PM
GenXr's Avatar
make sure you get IFS manual hubs. The body on them are slightly longer (or deeper) than the solid axle versions.
Old 05-13-2010, 10:14 PM
c0ugar69's Avatar
yea I am getting them from i believe a 87 runner IFS suspension. hopefully they go on no problem, fellow yT member made me a good deal.
icentropy
09-16-2020 02:47 PM
XtraCab
04-12-2020 05:25 AM
MMA_Alex
25
04-18-2017 05:07 AM
shar
07-09-2015 12:38 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 89 4runner IFS ADD or not
