89 4runner auto trans fluid change
Old 10-31-2015, 12:52 PM
8_9_runner's Avatar
Bought a 89 4runner with auto trans. Previous owner has no record of any tranny servicing. Is it safe to do a fluid change or does this trans react like a GM and "not leave the garage" as I've heard can happen?
Thanks for the replies.
Old 10-31-2015, 04:54 PM
maco35's Avatar
Just use non synthetic Dexron ATF when servicing your trans. and don't worry these trannys are bullet proof.
Old 11-01-2015, 03:53 AM
Truckwithoutaname's Avatar
Yes and be sure not to overfill it. The owner's manual is your friend.
Old 11-02-2015, 05:24 AM
8_9_runner's Avatar
I forgot to mention the mileage in case it matters. Approx 190k. And yes, I love repair manuals!
Old 11-02-2015, 09:23 AM
Janos01's Avatar
As long as the transmission is working normally (no excessive rough shifting, gears sliping) you should be fine. If there are issues but the transmission is working, I would not mess with it as changing the ATF when regular maintenance was not done could kill it.
diingodog
01-11-2018 10:39 AM
Blizzard
23
10-03-2005 07:31 AM
Quick Reply: 89 4runner auto trans fluid change
